Will do mate, I'll also get it on FBNice to know it's arrived - thanks Sean. Please post some pics when you have it installed.
No, it definitely said Rodney!!Thought that badge said "Rooster"
You can't beat a bit of "Only Fools" TonyNo, it definitely said Rodney!!
Always worth a smile Steve and always will be. Classic.You can't beat a bit of "Only Fools" Tony
You PlonkerNo, it definitely said Rodney!!
There is no way it will move Barry, it took a couple of knocks to get it all the way down, nice and tight, the wife will probably freeze something in the lunch boxWell done Sean, it is important to glue the sub-frame into the console though. If you don't, you might find the sub-frame may move about slightly which means the top trim will rub on the underside against the top surface of the console and that may leave a small dull line in your paint job. But if you're happy, then let it be. It is a very snug fit into the console as you say.
I see you have a nice lunch box too...
