Hi all, about to fit Discs and pads all round on 2.8 do I need any specialist tools before I start ?????
Brilliant, where do you live and what time do you want me thereDecent jack, axle stands, 1/2" drive socket set, impact wrench a massive help. If you're changing the fluid as well a pressure bleeder is a big help. Good pair of pliers, or grips. You might need a decent light / torch. Can't think of any "special" tools though. I'd recommend some gloves and something to clean your hands afterwards.
Pretty straight forward job
If you need a hand I'm happy to help, however it will be at least a couple of weeks before I'm free. This weekend is my last weekend at home before I go to Bahrain for a week and I won't be fit for anything the first weekend back, well according to Jill I wont beBrilliant, where do you live and what time do you want me there
Thank you for that oneBe prepared to peel back the boots around the pistons and find a whole load of cr4p in there. DO NOT just push the pistons back and hope it'll be alright, it won't be. That way leads to seized pistons and horrible brakes. It's best to pump the pistons out as far as possible without popping them out of the seals and clean them as much as possible, then slip some of the right brake rubber grease in there. I'm not the only one round here that's wound up buying new pistons due to corrosion on the original ones. And I won't be the last, either.
We all started from the same place, some are still there.Having all the right tools is one thing ....knowing what to do with them is another ..........as I am finding out
Ain't gloves wonderful. 20 for two quid at our nearest Asda.The sliders will probably be dirty, Do Not use sandpaper or a blade to clean them.
They're stainless. Use a plastic scraper, Cif/Jif cleaner, or brake cleaner if you have it. Then polish them with any kind of metal polish.
You can apply a Small amount of rubber silicone grease above if necessary. THEN CLEAN YOUR HANDS, THEN CLEAN THEM AGAIN. Be very careful not to get that grease on discs or pads.
Hi, is it definitely 7mm???7mm allen key for the slider pins on the caliper
How prevalent are rusted pistons? Looking to do my brakes and have the seal kits on order, but not sure if I need to also replace the pistons as well (of course, I’ll find out after I realize I do t have the parts I need)Be prepared to peel back the boots around the pistons and find a whole load of cr4p in there. DO NOT just push the pistons back and hope it'll be alright, it won't be. That way leads to seized pistons and horrible brakes. It's best to pump the pistons out as far as possible without popping them out of the seals and clean them as much as possible, then slip some of the right brake rubber grease in there. I'm not the only one round here that's wound up buying new pistons due to corrosion on the original ones. And I won't be the last, either.
