- Oct 19, 2014
- Model of Z
- 2.2i Sport
I wound up fitting the 325 mm discs from an e46 330 coupe on the front end, no problem there, but the rear pistons had corroded badly at an angle so that one side was a couple of mm shorter than the other, if you see what I mean, so I fitted new ones anyway. Expect to find corrosion, if you don't just imagine how happy you'll feel. These cars are all well into an age where these things will happen.
