E89 e-parking brake reset for pad change
Thanks @Lee for finding the info to do this job.
If you have no way of releasing the e-brake electronically with a service tool etc here is the manual method.
Its not a difficult job - but be gentle there are parts that are easily damaged.
Tools required;
Jack
Wheel chocks
Wheel Brace
Axle stands
Basic Socket set
T-30 Torx
7mm Hex drive (allen key)
13mm Socket
15mm (thin) open spanner
Thread lock
First thing once the car is off the ground ---- release the handbrake, turn the ignition off, lock the car, this way there is no chance of you waking the computer up during the process.
Here's the culprit viewed looking from the diff to the wheel (sat under the car) This is the e-motor that winds in the caliper piston when the e-brake is applied. Problem is its self adjusting and creeps out as the pads wear, so when you come to swap out your pads (or change disks too as I did here) you cant push the piston fully back in and you cant wind it back in from the piston end
****I wouldn't try to do this, I have been assured you can damage the e-brake gears in the caliper****
EDIT: There is a video on line showing someone winding the piston back with a screw driver? I did initially try this but my piston wouldn't wind in this way and I wasn't prepared to force it, maybe there are different systems fitted?
Word of advice, BE GENTLE, lots of plastic bits.
Once ready to start remove the power plug from the top of the motor, its the usual BMW type plug
On the rear of the motor viewed from the diff you will see two (2) torx, these hold the motor onto the caliper, they are T-30s. The right one is easy to remove, the left is slightly obscured by the shock, (Drivers side opposite problem on the passenger side) I used a sloppy ended extension to get myself around the shock, universal knuckle will also work. You will notice there is a bracket around the plastic casing, this will come off when you remove the torx, DONT forget to replace it when you reassemble.
When the bolts are out you need to pull the motor off the caliper, take care, don't use too much pressure with screwdrivers etc its plastic. I got hold of the motor and wiggled, and it came free, there is a rubber seal at the caliper side that hold the motor quite tight. Once off the motor can be removed from the car and put out of the way.
Red arrow is the direction to remove the motor (viewed from the wheel / disk side)
Blue arrow indicates seal location.
FYI Green arrow shows the motor drive shaft
With the motor removed the part of the mechanism on the caliper can be accessed.
The red arrow shows the dust plate covering the gears that drive the piston out.
The Blue arrow shows the drive shaft socket. This is the bit you are interested in.
You will need a 7mm Hex bit and I suggest a 1/4 drive ratchet. I would advise being gentle as you are about to wind the gears manually.
Insert the tool, set to tighten up (Clockwise) and wind away, if after about two turns it goes tight, (you've gone the wrong way or I have got my lefty looseys righty tighties wrong and you have put the brake on :whistle:) You should have to turn the drive back a considerable way, keep going gently until it stops, when it stops don't try to go any further (About 12 to 15 turns) (NB: when you are winding the mechanism out the piston wont move, this is correct you are in fact only winding the adjusting system behind the piston, you will still need to manually push the piston back later as in any normal pad change)
Once fully back you can now push the piston back with a screw driver as per normal (don't forget to loosen the fluid reservoir lid and check there is room for the fluid)
Next you will need a 13mm socket and a thin 15mm open spanner to remove the caliper off the hanger to access the pads.
Red Arrow 13mm bolt (requires thread lock during refitting)
Blue arrow 15mm (Thin open) spanner
Lift the caliper off, the pads stay in the runners on the caliper hanger, remove old pads (NB: the pads are not universal, there is a rear and a front dictated by the nipples on the pad back plate, if you get these wrong the front pad wont sit flush on the disk ---- check before you remove the old ones sorry I forgot to get a photo) clean or replace the runners, fit the new pads Once the pads are changed and the caliper refitted you need to wind (gently) the piston back out, keep going until it stops, then back it off one (1) full turn.
Refit the motor, the drive shaft should just click back into place as its a multi-drive, don't forget you are pushing the unit over a seal so its going to be tight (use a smear of brake fluid on it), just wiggle it
DONT be tempted to use the bolts to force it on as the housing is plastic and if you break the housing its going to be expensive.
The two torx for the motor require thread lock.
Don't forget to replace the bracket.
Repeat other side!
Torques:
T-30 Torx Motor bolts 11Nm
13mm Caliper bolts 35Nm
Once completed and the car is on the ground, turn on ignition, depress the foot-brake several times to set the pistons onto the pads. Keeping the pedal depressed activate the E-brake and then deactivate it (I did this several times.)
Nice, look forward to seeing some photos.
We need more info on the forum about the new generation E89.
Agree ill post some up
e89 needs it's own section :thumbsup:
Yes it does Niall, the first Z to get electric parking brake.
This post has been edited with my description and photos.
N
Great job Niall, very well illustrated mate.:thumbsup:
bessieblue
chelmsford
I've got a electric handbrake on my landrover, it works well but I can't see the need for these, much prefer a standard handbrake.
Ianmc
New Forest
Z3 (M44)
Just one more unnecessary invention, costly when goes wrong and really don't need anyway.
I think manufacturers run out of "things to do" on new cars. Like electic open/close tailgates which have percolated down the bloody pick ups now. Where will it end?
mwpe
Camberley
The more I see of new cars and all the unnecessary electronics the less I want one.
Indeed but as us e89 owners have it we have to maintain it.
Rha
Z4 coupe sport.
Most useless bit of manufacturing I've ever come across as a driver, so there you are with brake peddle to the floor with no reaction from the brakes and god help us all cos that electric hand brake can't be feathered, it's either on or off. Had one in the Fiat 500x along with emergency braking,lane control etc. Bit OTT when the car has to tell you you haven't indicated or you've wondered over the white line, what ever are they thinking of ????? I've got a wife for all that. :wacky::wacky::wacky::wacky:
:facepalm:Our new 500c is as basic as we could find, even got a starting handle and a spare wheel, it's a manual so the wife can bump start me.=))
The mind boggles.:bag:
RHA, Roy.
Rha
Z4 coupe sport.
Sorry Niall I did mean to say what a great write up for anyone contemplating doing this job,:thumbsup: nearly ruined your post with :spam:. Spose everything has its place in this new world of electronics, just that I really couldn't get on with electric h/brake on our last car. Old school not bold school.
Roy.
Redline
Nuneaton
E89 20i msport
Niall - Any specific reason for replacing these pads?
As the brake is only applied when stationary, I would expect any significant wear in them. Its not as if there's massive friction against a rotating disk.
What were the pads like on removal?
Great write up btw :thumbsup:
Just the one set of pads for HB and foot brake Ian not a separate system like the e85 / Z3 It was the disks that really wanted changing so new pads were fitted as they were over half worn.
Electric hand brakes don't use shoes inside the "drum" like Z3 and Z4 Ian, they're electric over hydraulic callipers. On VAG cars you have to connect a computer and "unwind" the callipers so that it screws the pistons back into the callipers. After fitting new disc (and pads) you pump out the pistons as normal. As with most braking systems lack of maintainence causes problems and electric parking brakes do just that.
Redline
Nuneaton
E89 20i msport
My misunderstanding.
Recall now the Disco had a single actuator that pulled cables against the rear pads - a simpler electric handbrake replacement. That is until you needed to move the car with a dead battery. At least there was a manual release for it.
No cables on the e89 though :thumbsup:
A what a pig of a job to change when it packed on, which was quite common.
mrscalex
Swindon & Swansea
I have to say I'm very grateful for every electronic aid possible on my 3 Series. I do 30,000 miles a year and I'll take every bit of help I can get to stay safe and alive with the state of roads and awful driving.
That said I don't like handbrake less cars and I'm glad my 2016 3 Series has one. Though I still get the benefit of 'hill start' presumably because it's automatic. I drove the new X1 (hire car) at the weekend and that did have one - didn't like it. Also I took the decison to lease my 3 Series with maintenance so it's not my problem when something goes wrong.
All the same I wouldn't know where to start with this issue if I had to face it needs must if you have ones so good post @Nodzed .
