Hi All, Have recently returned from a 600 mile round trip and experienced the following problems with the car:
After approx 3 hours driving the red battery light illuminated on the dash and the power dropped away from the car. It pretty much instantly returned and then repeated itself for a minute or two. I pulled over, switched the engine off then restarted and found that I'd lost power steering (it was also difficult to start). Switched off, restarted and power steering was back. Continued journey for about 30 minutes then had an hour and a half break before continuing with journey - no other problems occurred.
On the return journey the exact symptoms were experienced approx around the same 3 hour point of driving; loss of battery power, loss of power steering, difficult to start and all the corresponding lights illuminating on the dash. Stopped for approx 30 mins and for the next two hours of driving the car was trouble free. I've checked battery connections, battery condition (I use a CTEK trickle charger when she's not in use), have used a meter to check the state of the alternator and all seems fine. I've had a cursory check of wiring in the engine compartment and all seems okay. No overheat warnings during driving.
Since returning home have been out on short 30 minute drives and no problems with the car at all. Grateful for any thoughts on what might be the problem.
