I took the car for a run up to Rutland Water last Sunday and it ran sweetly with the fuel consumption looking better after the Terraclean. There was very little traffic on my drive and I took it easy on more or less motorways, but when I was near home I could again smell fuel when braking into roundabouts. A week of work has got in the way since, but this morning I have done some investigation.
Starting with what the mechanic told me at the Terraclean place that I had slightly too much oil in my engine. What he didn't do was smell it, which I have now corrected- yep it smells of petrol and is quite thin. I have carried out a compression test with no problems identified- all 4 cylinders are between 180 and 195 psi. Hopefully someone can confirm this is ok for my engine?
One thing I did notice was the difference in my spark plugs, bearing in mind I have blow-by going on (no black smoke or petrol coming out of the exhaust) it was interesting to look at the plugs. These were in new about 750 miles ago:
IMG_20160325_104150751
Note that cylinders 1 and 2 are very dark and wet, cylinder 3 slightly drier and cylinder 4 very dry. Which is interesting as the fuel pressure regulator is next to cylinder 1 and it is this that I suspect is faulty as my fuel isn't shutting off on the over-run. Can anyone confirm this 'logic' please ?
When it comes to the FPR this is mine
IMG_20160325_084112618
It's secured with a circlip and the manual says after taking this off it should just twist and pull off, but I can't seem to get it off. It twists and I've applied a reasonable amount of pressure to try and get it off but I don't want to force it. Is there a knack to this??
