Nothing to do with drinking guys, the nitrogen is stored in bulk in liquid form, as it is released through the system it becomes gaseous once more, it needs to be kept under pressure to keep it a liquid, it is about -176 degrees if you want to know, we used liquid nitrogen in the heat treatment business, it was stored in a bulk tank and then piped to the Furnaces at low pressure where it was mixed with ammonia to form the atmosphere. When we were deep casing components, sometimes they retained the high temperature structure due to carbon saturation, in order to fully transform the structure, you have to quench below ambient temps, to do this we purged the ntrogen from the tank at high pressure into an open tank, which gave you a bath of liquid nitrogen, we then submerged the components in this until liquid heated up and turned to gas, at which point the components had been down to -176 and fully quenched.
