I suppose you can use those on both settings as the head can turn.
The diagram also shows the head should be straight.
This will not be the case....that the reason why the normal one does fit, right.
After looking a second time.
At the bottom it would only use half of the mounting bracket.
Don't think that is a good idea.
It's better like it is, going thru and thru.
