Help / suggestions
Shelim Miah
Northampton
Hi All,
I'm tying to remove this grommet. As the sidelight bulb holder is still there (same as pre facelift 1.9)
My bumper the previous person smoothed out the facelift sidelights. So I need to retrofit them to the headlights.
Another thread suggested using a heat gun / pliers. I have attempted this and messed it up. Have ordered another headlight and need some suggestions.
Kind regards
I have done this twice now to 2 different zeds
2nd time was on my Orinoco above who's headlight would be difficult to obtain and expensive to replace
Dont have pictures but can tell you how i did it both times.
What i did is heat a knife blade up and carefully cut it off when had majority off used a sanding bit on my cordless drill to flatten down the last bits
A very early light will have the hole already there.
Stephen.
I have done this twice now to 2 different zedsView attachment 361549
Stephen.
Dad managed to save the day using a drill and drillbit. Then using a flathead small screwdriver to remove the edges and revealing where the slots are to twist/turn. Now a snug perfect fit.
I will just need the wiring/plug from prefacelift and join them or can I use the existing facelift ones?
