How to find the options specified with your Z Roadster
EnthuZiaZT
Heacham Norfolk
Z4 28i Msport
Snoops said:
Heck is stern so I would say rear wheel drive :D
Yes, Snoops, as we found out, it can be a problem when your uphill drive is DEEP in Snow, with a Merc that has the same orientation, it's just as well our old Landrover can come to their aid, using all four wheels :D
Jackster
Hi one of my option codes is
S818A Battery master switch :-?
Does anyone have any ideas?
Snoops
Red Rose Country
The switch serves as a simple way to interrupt the off-load current for electronic components on vehicles which are not in use (being transported, in storage). This increases the obligatory interval between battery recharging from 6 to 12 weeks (cost saving).
Vehicles that will have a long transport route or those for which longer storage times are envisaged (not in customer's hands), are equipped with this factory-fitted battery master switch.
Note:
The battery master switch is not fitted for all markets.
Google is your friend ;)
pgunter
Winchester
2.2i Sport Zedshed Special
TU, Stands for a made on a Tuesday.. lol.. Only joking.. its just a code added to a lot of things .. Seems the Germans like to be very precise on the coding. That way they can make sure you get charged for every last nut and bolt..
I knew my baby was born in August 1999 so happy that I now have the 12th as the day.. Also have the James Bond headlights.. as its says 'Headlight aim control' bugger if I can find where the bullets go though.. Would be good for the M25... Links Links.. Mine duncoff... then hit the button.. lol.. hmmmm
Boysie
West Chiltington, West Sussex
M Roadster S50
Headlight aim direction I seem to have this
Boysie
M Roadster S50
It raises or lowers the lights if you have weight in boot
It would be simple if BMW referred to it as the headlight levelling system/device. You should set this to zero before you take it for the M.O.T test because if the tester has to adjust it to zero he/she is obliged to advise of this on the advice sheet !!! Honestly.
Jonno Bee
The West Country
Exeter
Updated as the original process (strike through) doesn't seem to be valid anymore. Replaced with a new procedure which does work!
There is an option to save the data as a PDF file, so you can keep it on file.
This works for both Z3 and Z4 models (and pretty much any UK BMW too!) and all you need is the last 7 digits of your VIN number.
  1. BMW's VIN decoder seems easiest to use.
  2. Go to http://www.bmwarchive.org/vin/bmw-vin-decoder.html
  3. Enter the last seven characters of the VIN, and the Captcha characters.
  4. That will bring up your Z3's build data.
The PDF's look like this when created (using Rosie as an example 2001 2.2i Sport
Jonno Bee
The West Country
Exeter
Thanks Gaz. Useful gen. Didn't realise that the M steering wheel was factory fitted.
Cheers,
Jonno
Low Rider
Thanks. Did mine first time. Interesting to read the info.
2.2 & 3.0 Sport
Jim, if you PM me your email address and the last 7 digits of your VIN, I'll do the report and email it across to you.
2.2 & 3.0 Sport
Yes saw it earlier Jim, but better to have two offers rather than none eh?
