iPad help
Macca
Wisbech St. Mary
2.5l Msport
Can anybody tell me why when a page on a thread contains a lot of photographs it only displays about half of them and the the ones that are not displayed, show a small box with a question Mark in it? As per the title, this is on an IPad.
Titan
North North Yorkshire
sDrive35i
It's not just iPads. I sometimes get the same on the IPhone and with email.
Not sure whether it is a cache issue.
Hopefully someone can give a definitive answer.
Z3nt from m'iPhone on Tapatalk
Is that using Tapatalk on your iPad? It can be a pain on my 'droid phone as well on threads which have lots of images in it.
It's the same across the other Tapatalk enabled forums I frequent.
board
Staff member
M Roadster
If you can point to some threads that do it then I can have a test. It might be the images are hosted elsewhere, photo bucket for example.
If it is through tapatalk then it's probably more of an app/connection/cache thing. I cleared mine the other day and I haven't seen that issue
Macca
Wisbech St. Mary
2.5l Msport
I cleared my cookies and the cache but it's still the same. I'm using Safari on the IPad not Tapatalk. It does it on this thread viewtopic.php?f=4&t=1471
Snoops
Red Rose Country
To try and help you locate problem using Android and Tapatalk I can see all the pics in that thread and there are lots. :D
Snoops ont'apatalk
board
Staff member
M Roadster
Just tested that page on my iPad and all the images load up. What connection are you using when trying to access the page, is it 3G or a broadband, if broadband what is the connection you have? I think it might just be timing out with all the images trying to load.
B
badman gee
mine has always been ok.
never had any issues.
:D
Macca
Wisbech St. Mary
2.5l Msport
I'm using BT broadband and wirelessly. I don't understand "what connection" unless you mean wireless?
board
Staff member
M Roadster
Sorry, I was wondering if you might be using a mobile phone connection if your iPad supported it.
Are you able to view the images on a pc using the same connection to the Internet?
Macca
Wisbech St. Mary
2.5l Msport
Ok, I've checked on my laptop and I can view all the pictures. So I guess the problem lies with my IPad??
B
badman gee
you need educating in the way of technology sir.
:ymdevil: :ymdevil: :ymdevil: :ymdevil: :ymdevil:
Macca
Wisbech St. Mary
2.5l Msport
Well come on then, educate me....lol
board
Staff member
M Roadster
Is it the iPad one, two or the "new" iPad that you have? Also do you know which iOS version you have installed at the moment?
Macca
Wisbech St. Mary
2.5l Msport
iOS 4:2:1 iPad version 1
board
Staff member
M Roadster
maybe an update will fix it. I'm on iOS 5.1 on an iPad 2 and can't get it to fail. Are you able to try on another internet connection so we can see if it's your BT connection that might be the issue? Also have you been able to try from another device on your BT connection to see if the pictures load ?
Macca
Wisbech St. Mary
2.5l Msport
James, ive tried it on my laptop and it works fine. How do I update my ios? Reading up about it, it seems I have to delete my original ios to be able to download the new one. Is this right?
Macca,
Do you not connect your iPad through iTunes on your laptop? That should check your iPad is up to date and handle the major updates... Unless things have changed since I moved away from my iPhone 3GS.
Macca
Wisbech St. Mary
2.5l Msport
GazHyde said:
Macca,
Gaz, I have no idea what your talking about...lol. It's a bit above my level. How can I connect my Ipad through my laptop???????
