now is when you find out you forgot to fit the seal....
No. Definitely remembered.now is when you find out you forgot to fit the seal....
We started work on rebuilding that thing in mid-April. The cooling system was the last known problem standing in our way of actually driving and enjoying the thing after those 6 months.Bet you're happy now. So, onto the next problem...
Thanks Tony. There's quite a bit of fettling to do but that will be done as and when. Top of the list is servicing the wing mirrors and window mechanisms so I can get the door cards back on.Great news Rob. Now, what's next?
I've got a complete loom myself. But it's a big, big job to change the whole thing. A much bigger job in my view than for example an engine swap. The driver's side under the dash is particularly fiddly.Could you not source a replacement loom or part loom from Andy or Adrian if they have a suitable donor?
Fair point Rob, I think it sounds like the same fault Dino had on his car. May well be worth sending him a PM mate.I've got a complete loom myself. But it's a big, big job to change the whole thing. A much bigger job in my view than for example an engine swap. The driver's side under the dash is particularly fiddly.
I was looking at grafting sections from my spare loom. And it's still an option. But when you get a problem like that the loom fuses together all the way back to the fuse box. Depending on what's fused together I think discrete single wires end to end are simplest. But if I find the whole thing has become a molten tangled mess I may have to graft the loom instead. I don't think that will be the case as I was told the car was otherwise still running and working correctly.
Yes I read up about that previously. I would say it's the identical issue.Fair point Rob, I think it sounds like the same fault Dino had on his car. May well be worth sending him a PM mate.
