M54 engine viscous fan. Not sure if I have an issue.
Z3 project
Bear in mind that a car sat ticking over will never heat up as much as when it's being driven, so any amount of sitting running for 90 mins won't bring out any problems.
I know but with something like this there is no other way to test it (that I know). I can't drive down the road sitting on the engine and keeping an eye on it! For a start I would burn my bum. :D
the Nefyn cat
Actually in Nefyn. My, that took a while.
2.2i Sport
I've got one of those Creator 310s that gives live readings as you go, pretty sure it does engine temperature, but I'm miles from home so can't be sure. Might be better than leaving it ticking over for hours, never does an engine any good.
Just noticed that you could have asked for one as a birthday present from some nearest-and-dearest, bit late I know. Still, that's the power of the edit button.
Z3 project
I have a creator 410 but have only plugged it into the round OBD in the engine bay. Maybe I should try the SCART socket? I will need to cut a few cable ties, as it is now buried up under the dash. ;)
the Nefyn cat
2.2i Sport
The OBD11 (under dash) socket reads a whole lot more, and this being a Z3 you'll be needing it. There's also something in the rules of cars about the sockets' location, don't know if it applies to rebodies. It only takes one jobsworth type to get uppity about it......:whistle:
