still error free, really odd, maybe unplugging and re-plugging the lambda has done something, but i still think the lambda codes are related to the misfire. the misfire codes have now disappeared for now but then i havnt put that much mileage on it yet. job for this weekend is to find that leak, i did have the intake apart a while a go while messing with the cam sensor, now wondering if it leaking at the joint, maybe i got some grit on it? though after watching the co readings it would seem to be quite a leak. i will build my own smoke tester from an electric shisha which i have left over from the last time i tried to quit smoking (it almost worked, managed about 5 months, will have to try again)
