A friend of mine ask me if he could come and give a hand on the car (as he likes cars, doesn't know much about the mechanical part and want to learn about it). So yeh, of course he could come.....but he cancelled for today (he might be coming tomorrow).
Nevertheless that made me prep up to do some work on the Zed...thinking on what interesting things I could show him.
....so in the end I started dissembling the rear axle alone.
Disconnected and removed the brakes (as I didn't want my good discs to bounce off the floor when releasing the axle...
Removed the last part of the flex lines (goodridge will go in all round). The middle part was very hard to get to and the screws on the fixed-line-side or seriously corroded, so the bracket starts to twist when force is applied. As I will be changing the lines with goodridges, I just cut the flexible bit, so the I am able to remove the axle.
The diff bolt where hard (blocking the diff with a screwdriver - as brakes no longer worked and the gearbox is not connected for the moment).
All these bolt are corroded, rusted and blocked.
Undone the handbrake cable from inside the cabin.
Remembering how is was on an E36, it pushed out from the cabin, but on the Zed it doesn't move. (--> anyone know if the handbrake cable is fixed when going thru the chassis to the cabin? or if it is just the dirt build up that blocks it for the moment)
Loosened the shock-bolts (needed to put a 1m pipe on my keys).
Was not able to remove the mean bolt which hold the beam itself in place.
The compressor didn't do the job either (only a 8bar small compressor), couldn't get the 1m pipe in place, will need to try with something else.
Then the main thing, I know I read on here from
@Lee working on DinoD's car (I think posted by
@GazHyde) that the exhaust on the 2.8 is in 2 parts, so you don't need to take the whole exhaust off (in DinoD's car I think it was a SS-exhaust, maybe that why it was I 2 pieces). Well mine is not in 2 pieces. Started from the back unbolted and took the hangers off. Put the jack under the exhaust so that it wouldn't be damaged when all the weight is on the manifold. ....then realized I should jack the front up to get to the bolt on the manifold.............
....at that time I gave up. Supported the exhaust with something else, to be able to release the jack. But didn't start on the front any more.
Hope I will have the courage to continue tomorrow....and that the exhaust bolt would not snap off....and that the main beam bolt will release.
Wanted to start installing the front suspension (my new BC racing ones) this weekend too, but maybe that will be too much.
Regards, Koen
