NEW ROOF (SOFT TOP)
B
badman gee
As discussed 5 mins ago, not me!
I've seen it done and in too scared!
I did a soft top swap on my other zed, relatively easy. I brought the sealing compound in a real, remove the 18 screws along the inside (below the window. Disconnect the motor arm (pop a pin and the joint comes apart) then remove the 3 bolts on each side. give it all a good shake to break the old sealant and lift. Took longer to clean the old sealant off. took me around 3 hours.
FRANKIE
What did you use to clean the old sealant?
I have some wipes from where i work that contain alcohol. (Azo wipes) Great for cleaning surfaces.
FRANKIE
Your quote: I brought the sealing compound in a real..
Don't quite follow that, and its something I'm concerned about. Could you explain that again. Thanks. Frankie
Frankie, I'm sure that Lee meant a reel of sealant which would come on a non sticky backing tape where you would apply the sealant to the area required then remove the backing tape to leave the sealant in situ. Hope that makes sense.
Exactly what tony said. The harder way of sealing the roof was with a tube of sealant which gets messy.
This reel of sealant is the same stuff and easier to apply.
Brian4
Near Grantham
Z3 3.0i Auto
Don't forget once the seats are out don't turn on the ignition or the airbag light will come on, better still disconnect the battery as long as you have the radio code.
PS Good luck
FRANKIE
PS Good luck
My seats have some play in them and I think I must replace something,Bushings? while they're out.
FRANKIE
PS Good luck
I saw a post about this on another forum some one sent me to about the top. Something about spacers. I'll have to look at it again.
