P.O.T.M JUNE 2026
Location will be revealed later.
This location doesn’t look to be in England or the UK so where’s the spot your car melted? 🤣
She hasn't melted Dawn, although she has suffered in 44 degrees. All will be revealed later:whistle:
There are a lot of clues in the photo that it’s not in the UK. Top down? At least have the roof up for some respite from the heat or Heatstroke Central looms.
The location looks like either the Dordogne or the foothills of the French Alps? Even in 40 degree heat you do not really need to put the roof up - if you have air con and are dressed appropriately. I favour jeans, a long sleeved shirt with a loose silk scarf, thin leather gloves (sunburnt hands are not fun!) a baseball cap without the usual poly foam lining, and plenty of sun cream.
We have just come back yesterday from the Alps and over 35 degree we had the roof up as couldn't manage heat, under that we had the roof down with the A/C on. Unfortunately @Mint is having an A/C issues! 😅
Air con on with the roof down ? When we lived in Spain, if it was too hot ( 40 + degs most of the summer)for the roof down, it had to be roof up windows closed, air con on. Never drove with roof down air con on, seems counter intuitive.
I don't think it helps the air-con compressor either, as it's trying to "air-condition" the entire universe, instead of a small car interior. So the compressor is constantly working flat out, instead of cycling as required. Pondy can probably offer better advice on this subject.
