Ziggy*Dust
- Apr 13, 2026
Hi every1 I’m new to these type of treads so bear with me
can some body tell me if there should be a drain hole in the rubber shield below the petrol cap ?
Yes, it blocks up really easily and is difficult to see but there is a drain hole at the bottom of the creased section. Poke around with a bit of wire and you should find it.Hi every1 I’m new to these type of treads so bear with mecan some body tell me if there should be a drain hole in the rubber shield below the petrol cap ?
