Soooo after many years and much part fitting and tweaking my Z actually had some proper track day time.
LYDDEN HILL
1 whole mile,
All turns right except for devils elbow
The steering is not straight for more than a few sec.
You are on the brakes in quick succession.
Surface designed to take 600bhp rally cross cars so eats tyres!
Perfect spot for my first proper track day.
Oh and I was in the ADVANCED group as novice and intermediate were all full. They said it basically empty so I’d be fine...
Awaiting briefing, looking moody:
Good thing I didn’t smooth the two eye cover
Half a BMW (running the 4.8 V8 from the 650i - gentle Sunday cruise it was not!)
So I sign on and find out that since I booked the day day before 10 other cars have joined so the Advanced group is now full and will have single seater, bike engined cars and RallyX cars joining in the fun. I was the only on road tyres!
Booked the instructor for the first session and went out nervous as anything.
The instructor was great - without him I’d never had braked and turned so late or used as much power (basically full throttle in 3rd after pilgrims and briefly catch 4 whisky still turning, would never have dared but he pushed me on, seriously surprised at with this old shed can do!
Cool down between sessions:
I don’t run a a viscous fan and this feat was hot and I had the aircon on...ahem...its sweaty work ok and you have to have your arms covered and all I had was a fleecy soft shell!!!
Running like that the gauge started moving past centre so aircon off and back off after 6 laps and she was fine. Will need to run an additional electric fan or refit viscous (but with new engine mounts to help it not kiss the radiator).
Tyres did well for the first 5 sessions - I could feel them go off and would back off to let them cool. I also avoided understeer in the main which preserved the front corner. I had the ASC on for the first 5 sessions and could feel it holding back a lot.
I also like how you gain more rubber than you lose!
Ok the final session I switched of ASC and played a bit but the track was very hot - brakes were worn down so as a result I was tipping into the corners harder than the tyres liked so the front left corner took a beating as you can see above - gained some blobs to make up for the loss of writing on the sidewall though!
Single seater that spewed oil out all the time!
Managed to pass the Clio every session - quite please to pass something although I suspect he was new to it.
These old Fords are quick round here!
E30 325i stripped and on slicks - we evenly matched on power but on brakes and in the corners he’d just dive in the inside line (overtake ANYWHERE at Lydden provided its ‘safe’)
@spurs fan in a coupe throwing the Z in the bends.
These RallyX cars were so quick and distracting- they blast past without you knowing and then proceed to pull the handbrake at what must be 100mph, watch them too long and you lose your line and head for the grass!
