REAR DROP LINKS
stevie_a
Glasgow'ish
An update since i had the car up on the ramp today
if you listen to this you will hear the clicking (among other noises)
........clixky.........
The only thing i can see is the diff bush
what is the best way to replace this?
I was thinking taking the back plate off?
and what is this?
Finally where and how much are these ?
I seen one on e-bay that looks like it for £120
seams expensive i have seen others that look totally different for a lot less
Z
zedonist
The connector is the speed sensor for your speedo. The best way of doing this is to buy the bush already pressed in a new back plate, the are about £75 from the dealer.
Will post part number later if I get back on the Internet today.
Have the suspension dampers been mentioned?
A mechanic told me that a noise I have from the front is due to the struts inside the damper shaking and making a noise (as presumably some rubber part has come undone). No untoward affects just a noise (not that loud like yours but then the front suspension is far from the cabin..)
