red brake system warning light
littlefeller
evesham
as title, came on this morning, fluid level is ok, its intermittent (goes back off after about 20 seconds only to come back on again if i brake)
any ideas?
jonco
Chester
'98 1.9 Auto
Check your brake pads and wear sensors.
littlefeller
evesham
will do, does the brake pad wear sensor have an orange light? this one is red. the front pads were an advisory a couple of weeks ago.
5harp3y
Brake pad wear sensor is red light
circle with exclamation mark and 3 dashes each side (cant find a picture)
i know cos mine is on because the sensor snapped
littlefeller
evesham
no mine is like this.
hoping its just the pads as they do need swapping anyhow.
jonco
Chester
'98 1.9 Auto
The handbrake light has the P in the centre see photo below.
The circle with the dotted outer is brake pad wear.
The one with the exclamation is hydraulics - if the level looks good suggest you take the filler cap off reservoir and exercise the float and check if light goes out .
littlefeller
evesham
i have checked the fluid, will try pumping it with the cap off, just took it for a spin - exclamation mark red light flickers under braking, then when stationery it would flicker if i pump the pedal, the second time i was at a standstill i tried it again - now the wear sensor is flickering but no exclamation mark warning light. will have to wait till i get home and plug it in.
jonco
Chester
'98 1.9 Auto
I'm puzzled now - reason I said check fluid float switch was because mine stuck a few years ago. My level was actually low but no warning - exercised float which had stuck and has been Ok since but I always check it as a routine.
Just had a look in the handbook which has only basic info but does make reference to dual braking systems and combination of low level, excessive pedal travel and light on can indicate one system is failing.
As you say plug it into diagnostics and see if that tells you anything.
littlefeller
evesham
well a slight update, no need for diagnostics, the exclamation light has gone out and is now replaced by the brake wear sensor light (not sure why the hydraulics light came on first) thanks for all the reply's guys:thumbsup:
That'd be why your friendly M.O.T. Tester advised your pads were low then, which also leads to longer pedal travel, something you as a regular driver would hardly ever notice increasing.
jonco
Chester
'98 1.9 Auto
....... no need for diagnostics, the exclamation light has gone out and is now replaced by the brake wear sensor light (not sure why the hydraulics light came on first) ....
Hope new pads sort the problem - would be interesting to see what codes the diagnostics threw up.
littlefeller
evesham
he also said the rear discs were pitted and needs to be changed.
That can be a bag of rats Jason, depending on the condition of the back plates. Good luck mate.
littlefeller
evesham
Oh crap, there probably original parts, so I'm guessing lots of swear words are coming my way:(
Could be mate, after you get the callipers off remember to de-adjust the parking brake shoes before removing the discs though.
littlefeller
evesham
thanks for the heads up, i would have just lifted the car thinking this is straight forward.
I did a "How to" for handbrake cables Jason, pretty much the same job, might worth a look.
