Can someone please advise what torque is required to remove the 2 x lower bolts that hold the front strut onto the wheel hub? I ask because I would like to do this job myself and I want to buy and use an electric corded impact torque wrench to do it [I don't have air]. I also need the actual torque specs to reinstall if that isn't too much to ask!
I have been able to move them slightly with a spanner and a lot of force but jeez, if I slip I will be in hospital. Not interested in getting a breaker bar for the same reason lol.
BTW my Bosch Blue impact driver/wrench can [so it claims] go up to 180 Nm and will not budge those bolts. I put the wheels back on and used the Bosch and tested it with my torque wrench at 112 Nm and it tightened the nuts even more. I suspect the actual output was about 100 Nm.
Cheers, everyone
Cheers, everyone
