- Nov 25, 2012
- Location
- Newport, South Wales,UK
- Model of Z
- Z3 M43 1.8 (1999) and Z4 E85 2.5 (2003)
Its not that hard a job to take the outer sills off, take the wheel arch liners out and then work along taking the bolt/screws out underneath and the hidden ones behind the front side panel. Once free pull the sill out away from the plastic jacking points to reveal the inner sill and its condition. Best take those plastic jacking point inserts out and check clean any rust behind them. Once clean and front and rear ends are rust treated a good covering of clear Waxoyle should be applied, I coated the rears of the cover sills in black Waxoyle then refitted them using stainless hex headed self tapping screws/bolts. If you have to replace the cover sills get them painted before fitting to the car. As you are on a sloping drive maybe park the car on some blocks so you give yourself more clearance to get at the fixings and jacking points. Probably have to take the wheels off to get the wing liners out before putting the wheels back on to put it on some blocks.
