Whilst the unit pictured above looks quite stock, the main display is obviously the wrong colour.
Also I have found that aftermarket units do not power the amp if you have the HK audio setup, and as a result sound a bit naff.
My own car was fitted with a DAB sony unit when I bought it, which sounded rubbish, struggled to hold onto DAB signal and also looked very out of place. So I refitted an OEM BMW unit (made by Blaupunkt) and added a bluetooth module to it - I stream DAB stations from my phone and it looks and sounds a LOT better.
Personally, stick with a genuine original unit every time and add bluetooth.
