Cant tell, if its the main from the battery then I don't think so as that's the circuit that needs to be avoided if the positive terminal breaker is activated, battery disconnected (or totally dead) all that will do is try to feed back to the battery same as the jump points under the bonnet, what you need to do is activate the cars electrical system without using the battery supply route. I was told its a nut directly beneath the multi plug (looking from the top) that normally has a plastic cap on it, I am assuming its not the supply to the battery? You are probably in a better position to find it than me tbh, but I am relying on a third party info.
