Sean, not a problem - I think upgrading / improving a modern classic / classic car as opposed to a more recent car, is much more exciting and rewarding, so I understand your joy, and I guess others do too! Would you provide a summary and costs of this upgrade - I find it very interesting, as with other sound system upgrades done by members of this forum. This is something that is on my agenda over the winter months, all being well.
Ok, so I have my beer in hand and I'll give it a go,
I did the drivers side front first, removed the bonnet release handle, just one screw and it pulls off, underneath it you will see a clip that need turning 90 degrees, this is all that is holding the kick panel in place, the rest is just interference apart from a locating peg at the bottom, basically just jiggle it out,
there are 4 x 8mm head screws that hold the speaker in place, remove and take out the speaker which is connected to the wire with 2 spade ends, the new speaker just went straight in,
You can tell that this is going to sound better just by looking at it
Here it is fitted
I gave it a quick test then refitted the kick panel.
Next was the passenger front, just one clip that again needs turning 90 degrees with a flat screw driver,
I removed the 4 screws and got a bit of a shock when this lot came out,
I assume its something to do with the fact that the speakers are cross over and it controls the tweeters,
there is a single screw in the back that holds the speaker to the case, remove and give the speaker a twist as its also held on with double sided tape
New speaker connected, I also fixed it back onto the case with double sided tape.
Put it all back together and thoroughly enjoyed a 30 mile blast
Cost so far is
Sony MEX 4100 £50 of ebay
2X 13 cm Fli Underground Speakers £20
So for £70 there is a massive improvement and to be honest it is plenty good enough for me, however now I have started I am going to continue and fit the rear speakers, cost £30 as they are slim line, I will also add an under seat combined sub/amp cost £120,
Total cost for upgrade will be £220
