Spring fluid change/ top-up and lube clutch assembly to cure squeak!
JasMin70
Top up for spring, levels all checked, bit of the old WD-40 not bad for 27yrs old - also fixed squeaky clutch pedal - two bits of trim off over the pedals two springs that after a good splash of the WD-40 and voila - SILENCE !
Delk
Hemsby Norfolk
Z3 3.0T
The clutch pedal sits on two plastic bushings that do squeak after time and wear. Lubricating them does help but there is also aftermarket brass bushings that are easy to install as a permanent fix.
JasMin70
Nice, good tip thank you :thankyou:
