Stance?
Once you go past a certain point with lowering it just looks like you have a boot full of bricks, I don't get it, I don't like it. I think it just looks daft (even if it is just for show) :meh:
Redline
Nuneaton
E89 20i msport
They must be on air suspension just to get the look. Little or no use on our roads. Even on motorways you’re likely to rip the bottom out the car changing lanes as you hit the obligatory pot holes.
My nephew used a party trick as security with his air suspension though. Just jacked up three corners and left one firmly planted down on the ground. Looked like the suspension had collapsed so would put off potential thieves (hopefully). Not a look though.
DavidM
Ireland
Now, I do struggle with the "pedestrian" walkway on Triton Retail park in Lincoln. Once you go on to this site you cannot leave without crawling across this walkway. For safety's sake ,OK.
But if I were to do this to my car, I would be going out of the IN gate, that is for sure. Lower than a snake's belly.
View: https://www.youtube.com/watch?v=aYOuPHXgcwg
Looks great though - not many places where the car's belly wouldn't get tickled!o_O
stephen rogers
E85 Z4
Ok Nodzed ill take the bricks back out the boot then,i fancied building a barbie any way.lol.
I suspect Niall referring to the type of lowering where you can only see half the wheel let alone the tyre!
