I had intended to replace the thermostat, water pump and a bunch of hoses this weekend, but I was thwarted no sooner had I started when I wasn't able to remove the fan and shroud. I have ordered a tool from ebay that should allow me to crack on. I've since had a couple of suggestions for tips to remove it without the tool, although I doubt I'll have chance to try again before the tool comes anyway. Never mind, it's all part of the learning!
I drained the coolant though (another 'first' for me) and removed the rad hoses. I'm not even going to attempt to remove the thermostat until the fan and shroud are out though, I am terrified enough of sheering a bolt, let alone trying to extract them with very limited space.
Sadly I think I have discovered a PAS fluid leak.
With that done but it only being Saturday lunchtime and the weather complying, I did a few other smaller jobs too;
Replaced the broken footwell netting clips and fitted a storage net, cleaned the inside and outside of the washer reservoir, replaced my spare (which I expect would have crumbled if fitted) and gave the forward splash guard and spare wheel carrier a good clean. I want to de-rust and paint the spare wheel cage, but with the car on axle stands at the front there was even less space at the back and I couldn't undo the hinge/bolt for the cage, so that can wait for a later date. I also painted the front disc hubs, I'll do the rears next time I have the rear wheels off.
Sunday was going to be a day of rest, but when the sun was out I couldn't help myself and spent 6hrs treating stone chips that peppered the front bumper and bonnet using Chipex's 'Paint Chip Repair System'. At the end of the day, it's only paint, and it's never going to undo 25yrs of abuse and neglect by previous owners, but short of getting them professionally resprayed, I'm pleased with how the bumper came out. I'm going to have another go at the bonnet ones at a later date and see if I can build the paint up over time, because right now the stone chips are still really visible, it's just now they're blue instead of metal or rust coloured!
(mid-process photo when I was certain I had f***ed my bumper...
