So i have never removed a gearbox before which made me all the more interested to have a go.
If i'm honest the job is not really that hard you do need some specialist tooling but it's not expensive. Also the minimum of two people. I managed to get @GazHyde roped into helping.
I didnt really get time to take lots of photos but i will quickly explain what we did.
1) Get the car up on axle stands wheels can stay on.
2) Remove exhaust system from manifold back
3) Remove heat trays covering prop shafts
4) Disconnect guibo joint and prop shafts at diff end (easier with these out the way)
5) Remove clutch cylinder hook out the way also the gear linkages and any ancillaries
6) Start undoing the bell housing bolts (Inverted Torx fitting 11mm,12mm,14mm)
7) Once all the bolts are remove pull back the starter motor and wiggle gearbox free.
Enjoy
Enjoy
