The Gearbox is out!
@Brian H
3x Pin kit 23117525048 (Each contains 1 pin, 1 spring, and 1 lined bushing)
3x Sealing cap 07119937227 (RealOEM.com shows #23 31 7 531 369 for this, but the cap I spec fits the cap drift better and matches the original)
2x Pin bushing kit 23117542726 (This part number is not found on RealOEM.com, but is correct and can be ordered from a dealer. Each contains 1 lined bushing, 1 plastic-coated cap, and 1 snap ring clip)
1x Reverse gear pin 23311224849 (OPTIONAL, but recommended because of possible wear on original pin)
1x 5th gear pin 23317502165 (OPTIONAL, but recommended because of possible wear on original pin)
BMW bushing drift 233110 (DRAWING)
BMW sealing cap drift 232360 (DRAWING)
BMW bushing drift 234023 (Reverse gear pin. DRAWING)
BMW bushing drift 234022 (5th gear pin. DRAWING)
BMW sealing cap drift 234021 (DRAWING)
Self-tapping mini slide-hammer (BMW 230490 or equivalent)
Internal snap-ring pliers
Sharp punch or awl (for puncturing sealing caps)
Thanks @Lee did you make your own drifts?
I was going to but didn't get round to it. If I was going to do another I would. I used sockets instead which worked well.
