Bridgestone DriveGuard have good reviews and here is a test back to back between regular Bridgestones on the same car, quite hard to find a proper back up back test to genuinely compare: http://www.tyrereviews.co.uk/Article/Bridgestone-D...
I’m giving them a go on a Smax Fors (it has no spare but does not have runflats as standard! - would prefer the convenience of a runflat on a family bus)
My objection with Bridgestone is I have always found them to be high on noise once a bit worn. I recently changed two to retain matching set of tyres , 2 had gone down to 2.5/3 mm while the other 2 still at 6 mm. Think I may be making a mistake in always putting them back on the same location on the car when swapping over. If I rotate they may wear out evenly , hopefully then I can get back on Contis
Must say the Pirellies 210 held very well in a couple of inches of snow and zero temp across Wales yesterday.
