USB charge points
Parmst
Belfast N Ireland
Low Rider
An excellent idea I have seen these on here before but thanks for posting the link
Faheem
Leicester
I've seen things like this before on eBay but I've always been unsure on how you would wire these up?
I like that, where did you take the power supply from?
Faheem
Leicester
@t-tony Yes buddy that sounds brilliant. :) If you fancy it you can do it for me :thumbsup:;)
I'll get mine done and see how easy and quick it is Faheem. Then we'll see.;) I've seen some tidy looking items at the local Walmart.
Will do mate. When I buy the bits I'll post some pictures on here.
Bozzy
Long Eaton.
This is something I've been thinking of geting done on mine as well,be interesting to see what you can get over there @t-tony.
Steve
Steve
Keep your eyes peeled then mate!
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
That's a great idea @Parmst :p
Looks great ;)
Redline
Nuneaton
E89 20i msport
Nice solution. Is the cig lighter circuit switched or permanently live (like in the E85)?
If it's always on, you're likely to have an additional drain on your battery that may cause you problems if your car isn't used for a few days. If it's switched should be no problem.
Disconnecting the led will help of course but you've got a circuit dropping 12V to 5V that will always be drawing some current even if it doesn't have anything connected.
Parmst
Belfast N Ireland
The lighter socket is always on, will it still draw power when not being used ane the blue lights removed?
edit
just re read your post you have already answered me. Thanks
ppavuk
Balsall Common
Z4
edit
those switching dc-down adapters takes very little power when not in use, matter of 5-10 milliAmp i think. Of course depends on implementation, but take it 1amp when has load, 1-5% when no load should it be.
Redline
Nuneaton
E89 20i msport
Normally it shouldn't be a problem. You're adding a significant percentage to your static drain at 10mA. It all adds up over time if you're leaving you car for days and weeks at a time.
But, accidentally leave something plugged in..... Its so easy to do. :(
I bought these two items to enable relatively easy figment of a pair of USB charging ports. The plug in the left hand packet holds a socket to plug the charger into. This in turn will be connected to an ignition fed live fuse (same as my dash cam). The USB port block will be mounted at some convenient point in the cabin.
These parts come to $19.50 so not a bank breaker.
