I don't think so Tony, they would just apply a different set of ECU maps to control mixture and timing, much more precise method than just changing plugs.
I find You can buy any version for the same cost through ebay, I've never tried the EQUP, went straight to EIX, I have not tried the Bosch variant either, I wonder if they do an upgrade plug also, going to have a look......
Well for Bosch you can use either FGR7DQP or FGR7DQP+ and the interesting thing is they are both 6kohm resistance and were factory fit, so we can dispell the 5kohm issue from earlier causing misfires
