Hi, I know I am a bit late, been off-line for a while. I had exactly the same thing - the boot light dropped out and shorted - unfortunately the fuse didn't blow, it just melted and took out the loom exactly as you described. It is terrifying and I am please that you all got out safely! We did too and luckily I had a spanner in the boot to disconnect the battery. After the smoke had cleared we limped the 2 miles home. I took the passenger seat out and then took up the carpet. it took ,me a whole day but I managed to untangle the melted mess and graft in new wires where required - been going fine for 18 months since. I did however put a new, highly insulated boot light in too! It isnt the end of the world if you can catch it quickly!
Sounds exactly the same.
To answer
@t-tony I think the boot light either dropped or it was dislodged and pushed inwards when putting stuff in the boot that day so the exposed contact on the back of the light was touching metal. Normally it would pop the fuse straight away but this time like it
@NigeB didn't. The auto elec said it could have been just arcing a little to cause the wiring to heat but not blow the fuse.
To answer
@littlefeller it wasn't the 'loom of doom' as I've repaired that ages ago.
The only other circuit affected is the soft top motor (the fuse has blown on that). This was from the heat/melting of the boot light wiring.
It's affected other wires at certain points where there are really tightly bunched. After the firewall and into the bottom of the fuse box it looks like just the boot light wiring is melted, nothing else as far as I can see. That is probably the fiddlest part to work on as there is not much slack to lift up the fuse box and work under it.
Looking at I think it will take a professional very little time really as now the car is stripped and access is easy. Ifbitvwas summer I might have had a go at doing this myself as
@NigeB has done.
Ps
@NigeB can you post up a link of the replacement light fitting you used?
