Wishbone Bushes
TaffZee
Near Llangollen North Wales
Z4 3.0 SE
And the poly bushes are easier to fit (on a Z3 anyway) they come in two parts which makes it 99% easier to fit than a OEM bush. And is easily done on the car without removing the wishbone.
The hard part is getting the old ones off which way you go with the replacements.
Dickymint
Somerset
Z3 2.2i Sport
I have a plan to get them off by cutting out the rubber bits then using a puller, but how often does the plan you have pan out :p
ZTec
Llantwit Major
Wel I eventually decided on which bushes to fit, went for OEM ones. My thinking behind this was if it was good enough for the car on manufacture it'll be good enough now, and if I'm not happy I can always go for powerflex now that I know what's involved in changing them. Whilst doing them I also changed the front drop links, easy job. Well what a difference, totally different car, well pleased, glad I went for standard bushes.:)
David Cullen
Prosperous, County Kildare
there is no doubt that the poly bushes tighten things up and gives the car a better response to the road, there is way less movement or give in the bushes and this does transition to the cabin, i have had this experience in other cars and will be putting a full poly kit in the Zed as soon as i can.
again like a lot of upgrades it is a personal thing, for someone who likes the Zed as it is and likes how it handles then the choice is to go for OEM. If you are like me and you want to get more from the car handling wise and like to drive around corners rather than float around them then go for poly. for me i hear everyone say that the Zed handles great on corners etc but i disagree, i think there is way more the car can give with the right setup and that is the route i will be taking. Anyway, just said i would give my tuppence worth ;-)
Dave
