- Dec 8, 2011
Sounds like your keys are OK. I agree with one of the bullet points in the #6 post, and suspect the EWS (possibly the starter relay).
As the post says, make sure that you disconnect the EWS cable before jumping pins 7 & 8. When you jump pins 7 & 8 it will confirm that you refitted the starter motor correctly.
I did think about jumping it with the key in the Ign position and the EWS connected, but then considered "what if it is not the starter relay". You would be bypassing just one of the EWS "start/no start" things. - not a good idea.
