Z3 EWS Module Help Please!
Daniel28
Thanks again for all your help... I have no idea what I'm doing when it comes to wiring!
Heres a photo of what I have got - this is my donor car which is the road worthy Automatic not the race car...
mrscalex
Swindon & Swansea
It’s not there. It’s up and under the dash to the top right.
Daniel28
Struggling to find where the EWS is located... unless I’m blind haha
mrscalex
Swindon & Swansea
The connector has been cut off.
Follow the brake pedal up. You’ll see a thick black/yellow & black/green cable. They are the feed from the ignition switch and output to the starter
The other wires from the connector will be dispersed around that area.
I’m a bit worried for you what else has been cut?
I believe you can get the EWS ‘deleted’ when remapping it so that it works on any car/key.
