its probably the idle control valve doing its job...opening and closing to vary the idle via the ecu as it should...
this may help to show how it works...
http://ricksfreeautorepairadvice.com/how-does-an-idle-air-control-valve-work/
Hi Thanks for the post.this may help to show how it works...
HiVideo that I made last night showing an acceleration test followed by dropping the car into neutral. The revs dropped straight to 800rpm without hesitation...
Did your problem sort itself with a new thermostat? If so, OP should try that.I don’t know Pingu maybe the brain expects certain temperatures after a set period of time of the engine running and if not a temperature sensor error Is logged. Maybe just a theory that sort of made sense.
If it worked for you, it's a good solution to tryYes Pingu I know I’m not on your level of expertise just a cheap option to consider.
