Z3 wreck repair build-up (QLD Australia)
fuzz
Australian Zeds
Hi All,
Quick Update - The panel shop have said the car will be ready at the end of this week. Can't wait for that to happen, I can put all the panels back on and the interior back in. I also got myself a Nakamichi Stereo for the car which I've always wanted so I'll fit that up. Then onto a few more bit's and pieces and the registration. After that i'm pretty keen to do a 6 speed swap and either some work to this motor or something more involved.
Have a question though I was hoping could be answered. In doing the repairs I had to take out the passenger seat and the interior carpet. The car still had to be driven around the shop and on and off the tow truck so as you would know it's now thrown up the airbag light. I did expect this after reading the seat bushing replacement thread but it was pretty much unavoidable.
I have myself both the 20 pin and OBD connector and USB and i'm wondering if there is software I can get to clear this myself? With the VW I can simply get the VAGCOM software and reset. Is there an equivalent which will allow me to get this removed rather than going to a workshop? (Apart from the specialised airbag removal tools on ebay)
Cheers,
Fuzz
Hi@fuzz, looking forward to answers to your questions as I have the same airbag light problem. Also, when you get to these speed change would you please do an article with parts list, pics and description. Where have you found info on doing the swap and is an adapter required and if so are you doing your own or buying one. I like the idea but just not sure if the work is worth the end result. All my driving is hwy. so economy is the name of the game. Please post pics as you reassemble. JIM
fuzz
Australian Zeds
I've only had a quick look at it but seems like it's not going to be that difficult to do. As always cost comes down to what you're willing/able to do yourself. Here is some quick links but I have seen what you're after in other forums:
http://www.zionsvilleautosport.com/store/screen/prod/store_code/6134/product_code/6SP000.htm
http://store.uucmotorwerks.com/articles/E46M36spdtransmissionswap.htm
http://www.eatsleeptinker.com/2013/02/02/swapping-a-e46-m3-6-speed-gearbox-into-an-02-e368-m-coupe/
for me it's going to be worth while as I've currently got an auto and if i'm going to do a V8 swap or forced induction on my engine there's no point having the auto.
fuzz
Australian Zeds
no worries - I'll document everything I do but it's likely it won't be until mid next year.
I'm keeping my eye out for a V8 with a manual box already attached from a wrecked 545 or M5.
But each time I reset it I have to carry out the procedure twice! Is it me?
I sometimes find the B800 reset tool I have doesn't work first time, so probably not just you ;)
fuzz
Australian Zeds
Geez @fuzz looks like you found a Z3 petrol cap and are rebuilding a speed demo from that! :)
that is correct :) I get a bit carried away.
Nice avatar by the way... I'm looking for a farm down there. It is magic albeit chilly.
Cooper
Australian Zeds
Hobart Tasmania Australia
3.0i 2001
that is correct :) I get a bit carried away. Nice avatar by the way... I'm looking for a farm down there. It is magic albeit chilly.
When you come down for a look contact me as you will have a place to stay :)
fuzz
Australian Zeds
Thanks guys - almost on the road now. Just a couple of inspections to clear.
Quick question: the fan only works on 4. I get nothing in settings 1-3. Anyone had this or know if there is a fix without replacing the whole unit?
Cheers
You need a blower resistor, they control the fan speed on settings 1 to 3. If you have AC the blower resistor is located underneath the windscreen scuttle plate.
the resistor simply pulls out and you push in the new replacement. When you are in there, clean the 2 drains that sit in the bottom of the bulkhead, year of rubbish can collect in them.
Some more pics for reference: -
HTH
Brian
P.S. Your car is looking great, I love that colour :)
Z
zedonist
Ha Brian beat me to it, what you need to know is that it's blown, replacing it will get it working again, but it will also blow again, normal culprits are corroded motor bearings, so I would check them out, free them and lube them up
Not heard of the motor bearings Rich. I know the solder joints in the heater blower resistor can become dry joints and therefore give up the ghost.
Nothing wrong with giving the bearing a quick squirt of lubricant whilst you are in there though :)
Z
zedonist
It's a common problem Brian, happens on VW a lot, the resistor is actually a thermal fuse, they blow due to heat from excess current draw, usually due to bearings on the motor, if the Z was standing for a period then good chance the bearing or shaft have corroded a bit
fuzz
Australian Zeds
Awesome! Cheers guys.
Apologies I didn't search as I would normally but I'm stuck on an island where I only have sporadic patchy reception.
Looking forward to fixing that motor and resistor up in a couple of days and updating!
