have had chance to go through paperwork today and can confirm the following has been done
mot 28-07-2014 only needed washer jet unblocked and headlight adjust no advisories
current mileage 147500
four green service lights showing
powerflow rear boxes fitted 2011
following work done at 129566 miles
replace and remove oil filter
remove and replace oil level sensor
re-position air filter
remove and replace fuel filter
replace spark plugs
renew engine oil
remove valve cover check valve clearances-ok
replace gaskets x3
clean refit and adjust hand brake
remove and replace rear main oil seal
remove and replace engine block valve
remove and replace engine breather kit
remove and replace intake boot
remove and replace rear subframe bushes
remove and replace brake reaction bushes with uprated polyurethane bushes
remove and replace rear propshaft doughnut
dme software update
new 3 part clutch fitted at approx 120000
boot floor done along with new diff mount,rear springs,diff cover and oil in feb 2009
new water pump 2007
can not find any paper work to say vanos has been done but its quite and pulls like a train,if you require any other info or pictures give me a call on 07919343229
can is 5700 with hard top and winch and fresh seats or 4700 on it own
