Hoping to do this at some point this year. As a complete novice I'll have lots of questions...
@zedoniat From looking at the Alpine amp it plugs into any existing alpine head hint and then it's simply a case if running new speaker wires to the new speakers correct?
I already have a harness that adapts the Alpine head unit wiring to the OEM HK wiring set up. I assume I just remove that and plug in the harness from the Alpine amp?
Do the Hertz fit easily into the existing front speaker holes (down by your feet).
I see the rears need some help, did you strip out the rear plastics or just open the speaker grille and make room from there?
I've already got a sub, enclosure, small amp and wiring for that now just need to get the inline amp, hertz speakers and some tweeters.
Finally Any recommendation on tweeters and final position pictures?
