TBH 25kg ain't getting rid of 6" of suspension travel.Do you still have to fit the roof? If so, make sure you fit that, as that will be another 25kg-ish over the rear end.
Yep the bumper weights are there. everything is as it should be, except the arch gap.Do you still have the weights fitted that were under the rear bumper? They make a little difference - not much, but a little.
You will want to have the car fully weighted before you startmessing withcorrectingthe suspension heights.
I'm sure Pond has the body on straight. But if his body kit is anything like mine then the Arches are just gimongous.As Duncodin says it would be worth checking the height of the car along the sills to check how level it is. That would give an indication of the issue if it's body mount related or suspension related.
But I don't have any issues with mine. About 30mm between the top of the tyre to the arch both front and back.I'm sure Pond has the body on straight. But if his body kit is anything like mine then the Arches are just gimongous.
That, Sir, is a very good point.Ignoring the arches for a moment - how does the car as a whole sit? ie measuring at the jacking pads to the ground is the car level? If the car/chassis is level then lowering just the rear it"ll look a bit weird.
That depends on the adjusters. When I bought my coilovers i talked to ProSport who claims that nobody actually makes coilovers for Z3. The nearest he supplies is for E36 Compact. But, he said, they won't lower much at the rear because the Z3 has a lighter rear end than the E36 Compact.I reckon the coilovers will be adjustable to a maximum reduction of around 70-80mm, so all should be good.
So it's not the body moulding or the way it was fitted but the rear suspension on your car is 30mm higher at the rear. These cars are 25 years old and the previous owners have more than likely replace springs and shocks. There's no way to tell if they're OEM standard or some other dubious supply. Replacing the suspension will probably solve your issue.That, Sir, is a very good point.
So I have done some more measuring......the rear arch gap to the top of the tyre is 103mm. The front arch gap is 74mm (it looks like more of a difference TBH).
The ground clearance difference between the front and rear is 30mm, so it is sitting high at the rear.
One thing I have noticed from studying hundreds of photos of these cars (real and reps) is that they 'should' sit squat at the rear.
BUT...the suspension didn't look odd on the car when I got it (and I haven't touched it). It could be that the rear dampers are 'sticky' as they haven't been used in a while and are probably old. I have noticed that the rear suspension squeaks and creaks when raising and lowering the car, and when getting in and out, so that could be it.So it's not the body moulding or the way it was fitted but the rear suspension on your car is 30mm higher at the rear. These cars are 25 years old and the previous owners have more than likely replace springs and shocks. There's no way to tell if they're OEM standard or some other dubious supply. Replacing the suspension will probably solve your issue.
Tricky that without any seats, MOT, insurance or tax.Maybe needs a drive.
It's amazing how photos can make things look different.The crinckle paint looks good in the image around the steering column.![]()
