Dxbolton
Rather than bend the striker plate I tilted the handle slightly to get the same result. I used a long bolt from the push button to the plate and the push action is very light to operate. There is approx 1mm clearance between bolt and striker.That will give you problems. the striker plate you have added is too far away from the push pin on the door handle.
What you need to do is exactly what you have done but on your plate it needs to be bent towards you at 90 degrees. Then another bend of approx 9o degrees downwards. This places the new striker plate much closer to the pin of the door handle so it doesn't need to travel very far before it engages the plate and opens the door. The door handle pin must not touch the plate otherwise the car will deadlock, if it does then hopefully you have run the emergency release wire to the boot so you can touch the battery +ve to un deadlock the car.
I will try and do a sketch and post it later.
The Z3 central locking does not often fail but the deadlocking problem has been a major problem for builders, It was our own Gooka from this forum that solved it.
I am intrigued by Dxboltons solution, please keep us inform with lots of pictures.
I can easily release the door skin and remove it without any solid connected linkage.
@Duncodin you need to make sure you have access for modification or repairs. Whilst your idea is good, just make sure you can easily release the handle from the mechanism to gain access to the inner door.
