Bmw z3 running bad
Jlp
Yes unfortunately but I will get her back on road I'm on a mission now mechanics quoted me £500 all in so it needs to be done so i need to get it sorted car is running and can be used on short journeys because its only pressurising after about a 5 mile drive but I'm not going to take her out until fixed but nipped out last night just for ten minutes in her she drove great so that was somthing will let everyone know when she's sorted thanks.
Z
zedonist
This is why it's important to read the codes, as if there are none it highlights a mechanical failure and further more conventional investigation, it sounds like the gasket has gone between a cylinder and the water jacket, which accounts for rough running and misfires £500 is not a bad price, I assume the price includes a head skim?
Jlp
Yes it does my mechanic won't do it unless the head is skimmed he said because it won't work so as with head getting done its having a new waterpump thermostat and temp sensor all other cooling parts have been changed by previous owner ie rad pipes etc etc and I may as well have a full service oil fuel filter etc as with other post electrical system has been changed its had new Bosch coil pack leads and plugs £230 plus head gasket and service it's starting costing a lot !!! It's running now but unwise to use as head gasket is failing getting money together now as soon as I have will get it sorted me thinks I should have spent a bit more money and bought a decent one .
Z
zedonist
Once you've spent the money it will be a decent one, spending more on the purchase price could have left you with the same problems and more out of pocket...
Jlp
Yes I know the only reason y I'm doing it because it's only done 71000 miles and it's got bmw service history so it has been looked after for most of its life I think the lady who had it before the water pump must have gone and bust head gasket so I will have to get it sorted now
Jlp
Z3 finally in garage havin head gasket done and having head skimmed and she's having a full service oil fuel air filter waterpump new drive belts she's already had new ignition system inc plugs costing me £600 so if it don't run like she should this time I'm just going put dynamite in exhaust and light the fuse :thumbsup:
Should be great with all the work done! Enjoy it but don't blow it up, call me first!! lol JIM
Jlp
Thanks I won't blow it up its cost me to much money I think she will be ok once my mechanics sorted it then I can get her out on the road :coolsteer)
Good luck mate, summer on it's way. Enjoy.
Jlp
Update on head engineers said pressure test ok so skimming it mechanic said heater matrix pipes off back of head I think they are plastic where cracked so he changing those as well so he said should have her back on road for next weekend can't wait will be £500 lighter but I think my z3 is worth it thanks all Jason
Definitely worth it Jason. Happy Zedding.:)
