Mine are the same, look great in low light
Agree, had both CCFL ones and although they are good the LED ones are much brighter. I had the colour changing ones but the white was blue, so went for a set of 6000K ones off an E36 and they have been great although 2 do need a little cutting to get them to fit.Led ones way better. I have a set that you can change colour but I will swap out at some point due to the white being more of a blue for my liking.
@g8jka Do you have a link for the E36 ones you used?Agree, had both CCFL ones and although they are good the LED ones are much brighter. I had the colour changing ones but the white was blue, so went for a set of 6000K ones off an E36 and they have been great although 2 do need a little cutting to get them to fit.
Yesdoes anyone have the measurements for the angel eye rings, ie diameter?
They look different to the Z3 type as they are both the same size for each light, do they fit ok
Yes specific Z3 ones are different, but you can cut these down. One normal ring in each headlight is fine then you need to cut down the other one, I think it was by 9 LED's. As the wiring only comes out of one end the other side can be cut, normally every 3 LED's to keep the whole light working or at least that's what I did and 9 was perfect from what I remember. You can just cut through the casing with a junior hacksaw and fit the same as you would with CCFL's. That's if your fitting behind the inner lense I think, if you go infront like I have done I think I had to trim some off both rings but I can't remember. Could have been 3 LED's off one and 9 LED's off the other. They are even brighter as well which is a bonus.They look different to the Z3 type as they are both the same size for each light, do they fit ok
No I don't think it did, but I never used the relay. I think that's if you want them to dim on and off with the interior lights. I just used the live wire into the fuse box to an ignition live (can't remember which fuse) and the other to a ground. So mine only come on with the ignition. If you want them to dim on and off with the interior lights that's when you need to install the relay.@g8jka quick question; I've finally got round to fitting these and the wiring is a little more involved than the CCFL ones (5 pin relay, plenty of wires...).
Did yours come with a wiring diagram as mine did not?
Cheers for that @g8jka - all fitted now and wired in to the sidelights; dead easy!No I don't think it did, but I never used the relay. I think that's if you want them to dim on and off with the interior lights. I just used the live wire into the fuse box to an ignition live (can't remember which fuse) and the other to a ground. So mine only come on with the ignition. If you want them to dim on and off with the interior lights that's when you need to install the relay.
