Might be the gaptec interfering with the button operation if that has gone faulty. All that is doing is sitting across the inputs to the button array and looking for the sequence of button presses on the remote. That has to be one of the inputs. When seen it energises the respective outputs to the roof control as if the buttons had been pressed.Mine won't work on the button Mozz. Code read at work pointing at that being faulty.
Have you had the ashtray out but still connected to see if it operates then?
If not then its disconnect the gaptec and see if that allows the buttons to operate the roof.
This is why I'd rather have a cable harness built to intersect the existing plugs and sockets - would be a doddle to add and remove
