Fingers crossed
My usual, HiQ on Hermitage LaneWhete did you take it Jim?
Yes, the sills are truly rotten as far back as the jacking pointsDid it fail on the outer sills Jim?
I use 2 places. For MOT and basics - HiQ Mansfield.Never used them mate. My MOT guy is retiring to Spain later in the year so will need a new place.
Good to know pal thanks.I use 2 places. For MOT and basics - HiQ Mansfield.
For serious involved bits I use JMC in Sutton in Ashfield. He specialised in BMWs and Audi’s. Done engine rebuilds and everything for me.
Yes the sills are bolt on. But was told that if the corrosion is within 30cm of a structural join (I think) then its a problem.The outer sills are bolt on panels are they not? That makes them bodywork in my eyes, not structural. I will ask when I go on my M.O.T.training next month as one of the topics is corrosion I understand.
Agree. I knew they needed doing anyway when I bought the car so just gives me a push to get the sills sorted properly now.The outer sills are not even attached to the jacking points, they are just trim panels which go around them.
Whatever is behind the outer cover is the structural part. The sill covers are no more structural than the front and rear wings.Agree. I knew they needed doing anyway when I bought the car so just gives me a push to get the sills sorted properly now.
More concerned about what the actual sills and jacking points are going to be like once I’ve removed the sill covers.
Agree, but I need her to look prettyWhatever is behind the outer cover is the structural part. The sill covers are no more structural than the front and rear wings.
Absolutely Jim, I'm not disputing that it should be repaired and look it's best, just that I don't think it should have failed on those sills. As I said I will get a definitive answer next month.Agree, but I need her to look pretty
Agree @t-tony. As I have been following a lot of recent posts and discussions about sill outer skins / panels.Absolutely Jim, I'm not disputing that it should be repaired and look it's best, just that I don't think it should have failed on those sills. As I said I will get a definitive answer next month.
The effect of corrosion on the safety of a vehicle depends on the extent of
the corrosion and the function of the section or component on which the
corrosion has occurred.
A small amount of corrosion in an important part of a vehicle struct
ure can
make a vehicle unsafe where it compromises the load bearing capacity of
the structure. On the other hand, excessive corrosion on non structural
sections may have little or no effect on the vehicle’s safety.
Corrosion of a particular part, such
a
s a door
sill, may be very important on
one type of vehicle construction, but of less importance on another. This
can be seen
in figures 1 to 4
at the end of this Appendix,
where the shaded
portions indicate the important load bearing parts of various typi
cal vehicle
constructions.
