are the connections to the o2 sensor easy to test.. can you see if you got 12v to whatever pins needs to have it...?..
that youtube i just posted did say at the last 10 seconds that some ecus switch off the heater voltage if a 02 fault is present ...and wont switch it back on unless the fault is cleared ...
