What's happening in Lincoln Tony?So, if you would like to bring the car up to Lincoln.......
Who? Must be a Brit actor? JIMGaz looks like Jason voorhees with that grinder!
The psycho hairdresser car driver!
Just referring to " We know what we're doing ......... honest"What's happening in Lincoln Tony?
I saw some HB cables that looked like that recently.Lots of progress tonight and an early finish for good behaviour...
Lots of new parts from GSF, although someone forgot to order hand brake cables View attachment 11612
One of the stubborn beam bush support brackets bolts. This was cut off with the angle grinder, and the second with the dremmel due to poor access. About 1 1/2 hours work on these two
Starting to lower the rear beam.
The sub frame is free!
Ready to lift up on to the work bench...
Definitely needs new rear beam bushes, the metal centre has pulled away from the rubber...
Swing arm bush rubber starting to crack (ignore the rust )...
Diff bush collapsed when we put a screwdriver in it to see if there was any play. Plenty
Now if we only had some handbrake cables...
More to follow >>>
I've overslept... Got out of bed 15 minutes ago...This would explain why I'm feeling knackered this morning.
I don't think anyone is pointing a finger at you David. The PO obviously wasn't up to servicing a Zed or I imagine any car but it's in good hands now!! JIMOh fuuuuuuu........n!
Still thankful for the hard work boys.
For the record I'd like to state that for the time I have owned Scarlett (year and a bit) she has always been garaged, and for 7 months of that ownership, I have been away so she was pretty much permanently in there.
Pretty much what I am saying is that I deny any responsibility for her getting into this state! ...but I'm proud to be able to play a (small) part in getting her out of it!
Round Bad ///Boys for a night cap were we?I've overslept... Got out of bed 15 minutes ago...
It certainly looks that way to me too Lee. Everything appears heavily corroded.From what i can see none of this is davids fault, Its mearly had a hard life. I'm assuming from the ammount of rust that its been stored near the sea.
Other than where the oil was going. The inside of the exhaust should look new once all the crap gets burnt or blown out! JIMIt certainly looks that way to me too Lee. Everything appears heavily corroded.
